Trouble with DXFs exported by Fusion
danotranto
danotranto
I create DXFs for laser cutting, since the last update I cannot get splines to export correctly. The splines will either not appear in other programs reading the DXF (IE Corel) or they will be mishappen when imported to other programs.
Lots and lots of issues regarding DXFs on these forums since the last update it seems.
Is there any way to remedy this? The DXF to polyline app does not work any longer since the last update.
g-andresen
This should work with converters or applications that generate DXF with arcs from Fusion DXF.
günther
danotranto
I can't use arcs, I need to use splines.
