Trouble with downloading Fusion 360
filippmaksimov
filippmaksimov
I've downloaded Fusion Client Downloader but when I run it I receive message "The following installation pre-checks failed to pass. In order to ensure Fusion installs correctly, it is recommended to adress there issue before proceeding". Screenshoot is pinned
What should I do to solve this problem? Please, help me
jhackney1972
If possible, change to a network cable connection between your computer and your local network, maybe directly to your router.  Maybe try using a mobile hotspot from your mobile phone.  If you are using Windows, disable your Firewall temporarily to see if your settings are too tight.
John Hackney, Retired
