Trapped in a modal "file not found" error window.
rachaeleGXTF2
rachaeleGXTF2
Running OSX Monterey.  I clicked File -> Share -> Link and was met with a 404 ish type of page with no buttons and I have no way out. Even Quit is greyed out.
sutherland-
Hi @rachaeleGXTF2
If the file cannot be found, the data is either not syncing or the same hub is not being logged into. If so, try restarting Fusion 360, or navigate to the How to do a manual reset of the Data Panel in Fusion 360 section.
Please click on Accept Solution so other community members can see how to solve the issue.
Also, consider giving a Like to the comments that you feel helped you.
Best regards,
Level  sutherland-
Member
