Translucent design
Translucent design
welderQMQFT
Translucent design
welderQMQFT
What did  I do wrong? Design is translucent and doesn't come back if I activate it.
Edit. After looking around I can see others have had this issue as well.                              https://forums.autodesk.com/t5/fusion-support-forum/bug-shaded-view-some-components-translucent/td-p...
I did use fold/refold but how do I fix it now? I can delete it out of the timeline but it doesn't help.
dsouzasujay
Hi @welderQMQFT ,
We apologize for the inconvenience caused.
As a workaround, please unfold and refold to fix the issue. I have logged this internally as FUS-74841 for further investigation
If my answer helped, please 'Accept Solution'
Join Fusion Insider
Sujay D'souza
Autodesk Fusion
welderQMQFT
I wasn't sure which component to unfold/refold as I had already deleted the one that had caused the issue. I unfolded and refolded a component that I had made in it's place and nothing happened. After hitting cntrl+z  twice, to erase the unfold/refold out of the timeline, it fixed itself.
dsouzasujay
Good to see the issue got fixed with workaround.
Thanks for confirming.
Join Fusion Insider
Sujay D'souza
Autodesk Fusion
