Transferring project to new team
rozicuros1
rozicuros1
Hi there,
I am using a paid license and I am trying to transfer the project to another team. There used to be a "transfer" option for the project, but now I can only see the archive option.
Thanks for help
Rafal.Chlod
Autodesk Support
Autodesk Support
Hi @rozicuros1, thanks for posting.
If I'm assuming correctly it can be related to Manage Extension.
So far, there are some limitations with relationships between projects, files, and, for example, with data assignments such as Item Number coming from Manage Extension.
If you are using the mentioned extension, at this point the only option I can think of is to manually export individual files and import them into the desired team. There are a few ways to do that and they are described in this article: How to make a local archive (backup) file in Fusion 360.
If my answer helped you, please click Accept Solution. Thanks!
Rafał Chłód
Global Product Support
My Screencasts | Fusion 360 Webinars | Tips and Best Practices | Troubleshooting
