Trace tool path bug
Trace tool path bug
gmdimarzio88
Message 1 of 10
Trace tool path bug
gmdimarzio88
Since the April 2021 update I get this when i try to use the Trace toolpath.
Replies (9)
Message 2 of 10
g-andresen
What are you trying to do?
Please share the file.
File > export > save as f3d on local device  > attach it to the next post.
günther
Message 3 of 10
gmdimarzio88
Here's a dummy file. Same issue.
Message 4 of 10
jhackney1972
Well it works perfectly using a Fusion 360 Subscription License. @seth.madore has the rules changed for this type of toolpath under other Fusion 360 license types?  Model is returned, see if my toolpath gives you the error also.
John Hackney, Retired
Message 5 of 10
HughesTooling
Have you used Tilt and Turn in the past? Reason I ask is I get the same error with your OP but can create a new one. Just wondering if you used the extensions in the past and did a Make All Default. Below you can see in Compare and Edit your op has the degrees in black but my new one is green showing unchanged\default. I've attached my file, try selecting the op and select Save Parameters as Default and try creating a new trace OP.
Mark
Mark Hughes
Owner, Hughes Tooling
Message 6 of 10
HughesTooling
@jhackney1972  Did you try generating the original OP rather than create a new one?
Mark
Mark Hughes
Message 7 of 10
jhackney1972
Yes, it would not repair.  I then took your idea, right click on my generated toolpath, Save Parameters as Default, and tried to Generate his over again, it did not help.
Message 8 of 10
HughesTooling
There doesn't seem to be a way to reset an existing OP to the system defaults so no way to fix an existing OP.
Mark
Mark Hughes
Message 9 of 10
gmdimarzio88
I've been using that trace template for 3 years. And I do have a subscription license. This was working Monday. Did the update yesterday, now it's not working.
Message 10 of 10
seth.madore
There is a known bug that will be addressed shortly in a hotfix.
Seth Madore
