Tool path offset
Tool path offset
b.mcintyre
Tool path offset
b.mcintyre
When using 2D adaptive i have to give an offset of 3.775 to allow 3mm .
b.mcintyre
One more thing when i use the 2 contour offset is correct 3mm gives me 3mm.
MoshiurRashid
Whenever you are facing problem with CAM, I suggest you to post the issue in manufacture forum.
https://forums.autodesk.com/t5/fusion-360-manufacture/bd-p/2070
Moshiur Rashid
Autodesk Certified Instructor
ACP | CSWE
https://www.autodesk.com/expert-elite/overview
LINKEDIN | FACEBOOK
