tool path limit----partial path
I want to create a tool path which will only mill the top ramp and the two vertical sections of this part....how can this limit be set?
kate.raskauskas
Hi @Anonymous,
depending on what type of operation you're trying to do, you can either select the specific surfaces you want it to mill or set an angle range (ie only cut surfaces with slope angles of greater than zero) in the Geometry tab. Would that work with your planned workflow?
Kate Raskauskas
Product Support Specialist
My Screencasts | Fusion 360 Webinars | Tip and Best Practices | Troubleshooting
