Tool library: Paste from Spreadsheet doesn't work
m_baadsgaard
m_baadsgaard
I have my tools stored in a spreadsheet and just found out that copying them into Fusion with the "Paste from spreadsheet" function just throws an error "Failed to convert tools".
Which means I now have no tools for CAM.
I have tried older version of the library and I have used this method previously with this library with no issues.
m_baadsgaard
This is entirely down to the tool library version needing to be incremented.
That is very disappointing to have my library jeopardized at random like that.
jhackney1972
Please do not double post a question on the Forum.  Here is the link to your other post.
Second, you need to attach a sample of the spreadsheet you are trying to attach otherwise no one will be able to troubleshoot the problem.
John Hackney, Retired
m_baadsgaard
The forum didnt display the initial post after login and theres no obvious way to delete a post.
In any case I've solved my issue and learned that this feature shouldn't be relied on.
