Tool Library not responding
neil.heinemann71
Observer Observer
neil.heinemann71
Observer
Observer
Hi all I have come here looking for wisdom and I hope someone can help.
This is my first post on the forum so I hope I have done everything correctly.
Firstly I have trolled for days through the forum and tried all the solutions I could find on here and I still cannot open the tool library with out it going non responsive and having to force fusion 360 to shutdown.
I have reloaded graphics drivers and tried to put the library into classic mode which does get further but still becomes non responsive.
If anyone has a suggestion around this I would be grateful
these were the main sources of information which I have used and non seem to work.
Fusion 360 freezes when opening the Tool Library and the Library does not appear
Fusion 360 crashes when launching tool library in CAM
Modify Cloud Libraries/Tool Library Settings in Preferences
Here are some screen shots of where it gets to before stopping
Classic Tool LibraryClassic Tool LibraryNew LibraryNew Library
here is also the specs of my laptop
karina.harper
Autodesk Support
Autodesk Support
Hi @neil.heinemann71
Can you try turning on the 'new tool library' from your preferences? Does that improve the behavior?
Cheers,
Karina
neil.heinemann71
Observer
Observer
Hi Katrina
Thanks for your suggestion but yes I have also tried that with similar results. In fact it does not get as far with the new library on.
BR
Neil
karina.harper
Autodesk Support
Autodesk Support
Ok - this article might help. In particular you might need to add Fusion as an exception to your antivirus.
What OS are you on?
Karina
neil.heinemann71
Observer
Observer
Thanks again for the info. I am on windows 10 64 bit.
I have also tried with antivirus disabled with the same result.
BR
Neil
karina.harper
Autodesk Support
Autodesk Support
Ok - can you try the other suggestions in that article as well:
Cheers,
Karina
