title block not showing in fusion but is present, everything is unhidden.
isa47
isa47
the title block is fusion 360 is not showing up, but is in the drawing and can window over it
and see it (shows up in blue) I have reinstalled the program but still not working, read a post
about a patch that was made in 2022 for this but nothing was said after that. please help and
let me know what i need to adjust to get this to work.
isa47
also if I add lines in the edit window for the title block those also do not show up
lance.carocci
Hi @isa47, can you please include a screenshot or recording of the issue, and provide some system information? The issue sounds potentially graphics-related, so I am particularly curious about your hardware graphics card and driver version, version and release of Windows (e.g. Win 11 24H2), if your device has more than one graphics card or display, and if the issue reproduces consistently or intermittently.
Lance Carocci
Fusion QA for UI Framework/Cloud Workflows, and fervent cat enthusiast
liang_chen
Similar comments as Lance. This issue seems to be related to graphics card and driver. Please try to update the drivers of all graphcis cards, or disable the integrated cards if there are more than one. Restart OS and check if it works. Thanks
Fred Chen
SQA Engineer
Quality Assurance Team
Autodesk, Inc.
Steven.ayars
Thank you both for the feedback. Yes, it is related to the graphics card. I am running Fusion on a VMware virtual machine to see if it will work with
all our machines, and I need to be able to revert to a usable version if I need to. So that's where the trouble is. Thank you (liang_chen). Once I disabled
the graphics, it popped back up to use; however, it is not usable as the screen is small, so I have to research what to do.
