Title Block & Fonts fail to render in Drawing mode on MacOS
Ceritain fonts do not appear on the drawing page. I created a drawing for a desk that I am working on, but immediately noticed that there was no text in the title page, and the text where the dimensions should go was not rendering.
Following this, I changed the Document Settings's font from Arial to Andale Mono, and the text begins to render. You can see this in the image below.
As you can see in both images however, ther is no text that is rendering in the bottom title block, however, there still is text there (as I have highlighted it). I have attempted to find a way to change the font in the title block, but am unable to find one. I have included examples in a table; the left side shows a list of fonts, and the right, the result of chaning text to that font.
Note: When exporting, the text is able to be seen on the pdf.
Troubleshooting steps taken:
- Restarted
- Changed the Qt Rendering Hardware Interface API to each available option ["Automatic", "Metal", and "OpenGL"]; Note: these are the only options available.
- Repaired installation
- Uninstalled Fusion, then Re-installed
- MacBook is up to date, Fusion is up to date
Information:
macOS 26.3 (25D5087f) on MacBookPro16,1
Fusion 2605.1.52 x86_64 [Native]
In the iterim, I will attempt to create a custom titleblock that uses a different font as I wait for suggestions.
Graphics Diagnostics:
[GPU Information]
GPU Device: AMD Radeon Pro 5500M
GPU RAM: 8176 MB
GPU Driver API: OpenGL Core Profile
[Graphics Effects Settings]
Use high-resolution graphics: On
Anti Aliasing: On
Ambient Occlusion: On
Object Shadow: Off
Ground Shadow: On
Ground Reflection: Off
Selection Display Style: Normal
Transparency Effect: Better Performance
