Threading changed the shaft size.
Bertho_Boman
Message 1 of 12
Bertho_Boman
I have a 3.00mm diameter shaft, 80mm long.  I created a M3 thread, 6mm long on one end.
The threading worked as expected except Fusion changed the whole shaft diameter to 2.93mm.
Replies (11)
Message 2 of 12
jhackney1972
I have no explanation for the reduction in diameter but if you put a thread relief in place, you need it anyway, it will not reduce the diameter of the shaft.  Model is attached.
John Hackney, Retired
Message 3 of 12
Bertho_Boman
Thanks John,
I forgot to mentioned that I as a bypass fixed the problem by first reducing the threaded section to 2.93 mm and then thread it.
My question is why does this happen.  Fusion should not change shaft diameters.  Do I have some configuration setting wrong?
Bertho
Message 4 of 12
jhackney1972
Looking at the Fusion 360 Thread Table, ISOMetricprofile.xml, you will see the table specification calls for the diameter size you get.  Why it applies it to the complete shaft is beyond me.
@jeff_strater, do you have any ideas or do we need a repair ticket?
Message 5 of 12
TheCADWhisperer
Split the face of the cylinder before adding thread.
@Bertho_Boman
Attach your file here if you can’t figure it out.
What standard are you using? Can you link to reference page of the thread nomenclature for the standard?  What class of fit is your Design Intent?
Is it physically possible to assemble a 3mm cylinder into a 3mm hole? (Without using a press.)
Can you show Section View of assembled mating parts (threaded cylinder and hole)?
What manufacturing processes will be used to create the threads?
All of these are relevant questions when considering helical threads.
Message 6 of 12
g-andresen
If you measure the shank diameters of various standard screws, you will find that they are always smaller than the "nominal diameter".
For example, an M6 screw has a shank diameter of 5.89 mm.
günther
Message 7 of 12
Bertho_Boman
Note,  I am not questioning the thread dimension.  The threaded section is correct.
My point and big surprise is that Fusion changed the whole length of the shaft, not just the threaded section.
That is definitely an unexpected behavioral to me.
I specified the length of the thread so the changes should only apply to that section.
Bertho
Message 8 of 12
Bertho_Boman
As I mentioned, the generated threads are correct.
The changed dimensions of the shaft is not correct.
I understand how to work around the problem but I should not have to do that.
I finally caught the problem when I was preparing the documentations and drawings for the shaft and I was surprised that it had changed from the 3.00mm.
How can this thread be turned into an error report?
Message 9 of 12
TheCADWhisperer
No work around required - only logic.
The Fusion team is aware of this functional behavior.
It has been discussed here many times over the years.
Message 10 of 12
Bertho_Boman
That is good that the Fusion team knows about it.
As far as I am concern, having to separately create a reduced section in advance to threading, is a workaround.
I realize that threaded sessions normally  have separate areas or dimensions.
This also opens up a question of specifying the threaded length.
If my reduced section is 6mm long and I happen to specify the thread length to 6.5mm, presumably it will surprise me and change the whole shaft.
In the next project I will have to be careful and hopefully the issue will be corrected.
Bertho
Message 11 of 12
TheCADWhisperer
@Bertho_Boman
Not necessary to separately create a reduced section - that would be a workaround.
The best technique in current release of Fusion does not require that and is fully parametric.
Message 12 of 12
Fabbunny69
I have just experienced this, any update?
After specifying a thread of a certain length, fusion changes the shaft diameter beyond the length of thread i have asked for.
How can it be logical for fusion to change something you have not asked for?
Workarounds should not be needed to stop fusion doing something that must inherently be an error in internal coding.
