Thread label in drawing will not work when thread is created with thread/coil tool.
rrodriguezF5XQ6
rrodriguezF5XQ6
This is a new issue since the last update.  If I create a thread using the thread tool.  It will not label the thread in the drawing environment like it used to.
jhackney1972
I do not see any issues.  Please attach your Model that you are trying to create a drawing of.  If you do not know how to attach your Fusion 360 model follow these easy steps. Open the model in Fusion 360, select the File menu, then Export and save as a F3D or F3Z file to your hard drive. Then use the Attachments section, of a forum post, to attach it.
John Hackney, Retired
rrodriguezF5XQ6
OKAY SO I TRIED TO RECREATE THE ISSUE ON A SIMPLE MODEL AND I WAS UNABLE TO RECREATE TO PROBLEM IN THE NEW MODEL.
I will dig into my model and try to redo the features that had the issue. If I can reproduce the problem I will attach the models.
As for now, I guess I don't need any more help. Thank you none the less.
