Thread function does not respect chamfers on model body
Here's an example of how the THREAD tool in the F360 Design module does not respect CHAMFER features on models when "Full Length" is turned off.
I created a screw and then made a shank area that will remain unthreaded, and then a longer area that I would like to thread.
On this particular screw, there is a long chamfer where the transition to the threads are, like so:
Then when trying to thread just the remaining smaller diameter section, this happens:
As you can see, it ignores the chamfer, and extends the body section that the thread is applied to all the way to the base where the chamfered area is connected to the larger shoulder.
with "Full Length" off, it should just end the threaded portion at the declared length should it not?
I should mention that the thread tool suggests M7, but I know the thread for this particular fastener is M8x1.25 and these are the exact measured sizes I have put into the model, so that's why this is bothersome. It's not letting me just thread the smaller diameter section, instead it is creating an extension to the root of the chamfer.
Seems like a calculation bug?
