This document contains unresolved components error
bora2002md
bora2002md
I am on MacOS BigSur and Fusion 360 2.0.9930
Getting this error in my many projects and making me crazy how can I fix this problem.
Tried to clear cache reinstalled fusion but error still
continues.
dsouzasujay
Hi @bora2002md ,
Sorry to see that you're facing this problem. Would you be able to invite me (Sujay<dot>dsouza<at>autodesk<dot>com) to that project? And point me which file and which folder is giving you problems.
Also, please send your diagnostics file, You can generate it from Support and Diagnostics->Diagnostics Log Files.
If my answer helped, please 'Accept Solution'
Join Fusion Insider
Sujay D'souza
Autodesk Fusion
bora2002md
I send you request to the one of the projects I am getting error. File name is c1.
And here are my log files
dsouzasujay
@bora2002md ,
I can't open the file, It may be because some of the External Reference are in different project.
Or maybe you have deleted the project that had External Reference referencing C1
You need to invite me to other projects.
Join Fusion Insider
Sujay D'souza
Autodesk Fusion
bora2002md
Sended the invitation
bora2002md
Any help?
My printer is starting to erase 😄
