Thin extrude taper
Thin extrude taper
Chuffmechanicalengineer
Thin extrude taper
Hi!
I don't think that this issue has already been reported, but there were a lot of other search results for 'thin extrude', so forgive me if it has!
I have been trying to use the 'thin extrude' command, with a taper angle. This appears to skew/rotate the entire extrusion, instead of the proper behaviour of tapering it.
HughesTooling
I think the idea is the extrude is at an angle not the wall being tapered. If you select more edges it makes more sense.
If you want a tapered wall you'll need to extrude then use draft to add a taper to the wall\walls.
Mark
Mark Hughes
Owner, Hughes Tooling
That sounds like a bit of a strange feature, but I see what you mean. I'm sure it usen't to work like that... I'll post a message to the Ideas board, to see if we can have the old functionality re-added in a different parameter. Thanks!
jeff_strater
I don't believe thin extrude ever has worked so that the thin part itself is tapered.  Its entire intention was to produce a constant-thickness body from a set of input curves.  Similar to what you would get from extruding a surface body and thickening it.
Jeff Strater
Engineering Director
