The specified rendering could not be found.
Message 1 of 14
After local rendering is finished i click on the thumbnail to view and save and this comes up and i am not able to view or save the image. I can only save images by in-canvas rendering. How can I resolve this problem?Fusion 360 Render Issue.png
Replies (13)
Message 2 of 14
masa.minohara
Hi @Anonymous,
Thank you for posting in the forum! Can you find the rendered image in this page? (You will need to sign in on that page)
If the result does not show up, could you try Local Render again to see if you can open a new one?
Masanobu Minohara
Product Support Specialist
Fusion 360 Webinars | Tips and Best Practices | Troubleshooting
Message 3 of 14
spongman
i have the same problem. just updated to latest version and now my local renders are just disappearing after they complete.
what a waste of time.
Message 4 of 14
abreu.mec
Same here... cannot render all together. Just checked the page posted here for the online renderings... none of the missing renders were there! Is it to be regarded as "normal" for the time being? This is not a new issue, as I gather.
Regards
Alexandre Abreu
Message 5 of 14
Markclayto
I am having the same issue too identical cloud render works local render will not.
Message 6 of 14
derekmcleod
Same problem for me. Local rendering was working great until yesterday. Tried a test with a part of a large model and the test would show up and allow to be saved whereas the whole image would not. Tried in offline mode to see if that helped. Going to try re-installing Fusion now.
Message 7 of 14
Flerbizky
I'm seeing too - but it's random, 7-8 out of 10 renders works fine. Then "The specified rendering could not be found.".
And the picture is not on the Renderings Beta page either - I can see the last 4 renderings of what I'm doodling right now in the correct folder.
Most odd indeed..
Cheers, /Steffen ( :
Message 8 of 14
Im just recently Having the Same Problem..
Anyone Figure this out?
Joe
Message 9 of 14
LogicSpeaks
I'm having this same problem in the year 2020 - original problem appears to have occurred in 2018.  Has this been fixed, what is the fix? What do I do.
I have checked online to see if I have them uploaded there. No.  I cannot view any rendered image.  I changed quality.  nothing. I turned off cloud connection and rendered again, nothing.
What is going on? Why can't I save my renders?
Thank You in advanced!
Message 10 of 14
pepsimusic
Observer
Observer
2025 and I have this problem tried to reset app reinstall nothing helps
Message 11 of 14
pepsimusic
Observer
Observer
I have same problems with fusion in 2025 I tried already reinstall clean cache what I could read on forums nothing helps
Message 12 of 14
stefan_sullivanW77YH
I'm also seeing this problem starting today. Did a recent update to fusion break local renderings?
Message 13 of 14
pepsimusic
Observer
Observer
On my laptop I can do only in canvas render in Insider and stable version. On my other pc it's working
Message 14 of 14
GillesJrBisson
Everybody saying "I have the same problem" and yes, I do too. But can someone from Autodesk actually answer ??? What is the problem ??? Simple local rendering, what could be wrong ??? It renders for several minutes then the render just disappears without a trace. WHAT IS WRONG ???
