The design is being saved and synced to the cloud. Rendering will be enabled when done
msanchezame
msanchezame
Community Visitor
Community Visitor
me sale "The design is being saved and synced to the cloud. Rendering will be enabled when done." al darle a renderizar. pero el archivo esta guardado en mis documentos y demás.
sutherland-
¡Hola! @msanchezame
Try the following to resolve the issue:
1. Manually select to work offline on the offending computer
2. Open the design with the sync issue from the data panel while in offline mode
3. Make a cosmetic change and then save a new version of the design while in offline mode.
4. Go back online and see if the design will sync.
Read more about offline mode in the following link:
Also consider the following procedure:
1. Make a back-up of anything that has not saved to the cloud.
2. Clear the local cache.
See Also:
Please click on Accept Solution so other community members can see how to solve the issue.
Also, consider giving a Like to the comments that you feel helped you.
Best regards,
Level  sutherland-
Member
