Text using Monotype Corvisa font creates extra space after "d" characters
coachc
Observer Observer
coachc
Observer
Observer
When using Text with the Monotype Corvisa font, and extra space occurs after "d" characters. For example the text "Happy Holidays" renders as "Happy Holid ays"
jhackney1972
I do not see the same error.  I have attached a zip file containing the font type in both TTF and OTF format if you want them.
Edit: I will mention if you are going to replace your Font with the one supplied, make sure Fusion 360 is closed when you do it.
John Hackney, Retired
coachc
Observer
Observer
jhackney1972:
Thank you for the quick reply. I did not get the attached font in the
email. I will check the forum site. Attached is a screenshot of some
text using the Monotype Corsiva font to illustrate the issue.
Both lines of text use the same font. When I replace the 'd' character
with the 'c' character you can see the difference in spacing of the
characters. This also seems to happen with the "L" character.
Chris
coachc
Observer
Observer
Thank you for the quick reply. I will try using the supplied font to see if that fixes the problem. Attached is what happens on my system. Font Height: 0.394 in, Placement is on a straight line path
jhackney1972
I see no problems at all.
coachc
Observer
Observer
The spacing between the 'd' and 'a' in "holidays' is larger than the
spacing between the 'c' and 'a' in 'holicays'.
