Text size on my computer.
hossackY8L9Z
hossackY8L9Z
I am new to Fusion 360 and I am working with a new Dell precision 7760. None of the you tubes or help desks answer my problem. The texts on the canvas and the command lines are too small. I am getting headaches using the program.
How do I change the general text size?
Accepted solutions (3)
jhackney1972
I am assuming you are using Windows operating system.  There is a setting in Windows to change overall text sizes but this setting does not change the text size in the Fusion 360 application.  Your best bet is to use the Make Everything Bigger on your display settings.  The dialog box below is from Windows 10 but a similar setting can be found in Windows 11, simply go to your Settings and search for it.
John Hackney, Retired
hossackY8L9Z
Thank you very much for your reply. But I am working with windows 11 and I cant find a ‘make everything bigger’ in settings.
Is there somewhere else I should look?
One the subject of windows 11. I am seriously unhappy that they put my files on the cloud. I want nothing to do with the cloud but seem to have lost files before I found out what was going on with 11.
Regards Norman
jhackney1972
Here is the setting for what I described earlier on Windows 11.  Go to Settings, Click on System, then Display.  As far was saving your Fusion 360 files in the Cloud, this is the way Fusion 360 works on all operating systems.  You have the option to Export your files locally but this has many disadvantages.
hossackY8L9Z
I am being asked to click an "except solution icon." I can find such a thing. where is it and what is it?
jhackney1972
The Accept Solution icon appears at the bottom of a Forum Post entry page, your last post is shown below. To see this icon, you must be logged  into the Forum as you would to post a question.  You can read about the purpose of this icon on this webpage.
