text issues within the Fusion 360 interface.
davidsweeting3
davidsweeting3
Community Visitor
Community Visitor
I am unfortunate enough to be partially sighted and I have just upgraded my laptop, It now has better graphics than the other one I had and now I am having trouble seeing the small text labels in Fusion. I have tried to find a setting to increase the the size of the text but I'm not having any luck.  I have set the text size in Windows setting to the maximum size and this hasn't helped.
Has anybody got any idea how to make the changes needed?
dsouzasujay
Hi @davidsweeting3
Could you please provide more details?
When you mention "Text," are you referring to text within 'Sketch'? Please elaborate. Including a video or image would help clarify the issue more effectively.
If my answer helped, please 'Accept Solution'
Join Fusion Insider
Sujay D'souza
Autodesk Fusion
davidsweeting3
Community Visitor
Community Visitor
The text I was referring to is such as menu items,dimensions when sketching
and items in the browser.
dsouzasujay
Hi @davidsweeting3 ,
To make Fusion's menu font larger on Windows, please increase the DPI scaling in your display settings, and then close and re-launch Fusion.
Kindly note that adjusting the resolution specifically for the Fusion application is not currently a feature available within Fusion.
Join Fusion Insider
Sujay D'souza
Autodesk Fusion
