Wouldn't be the first seemingly obvious oversight I've seen in an update. Hopefully it gets corrected quickly though, as it makes trying to create signage quite annoying. Another workaround I found is to create a sketch using the text tool shortcut instead of making a sketch and then clicking the text tool.
For example, I have my text tool set to CTR+T and when I click this and then select a surface or plane, the sketch begins with the text tool already active. For some reason (probably a bug/oversight) this bypasses making the textbox parametric so you don't get the single apostrophes. Thus, no issue using it in your text either.
Looks and acts just like the old textbox.
I swapped back to classic theme (again) because dark mode still has a color issue with being unable to change the background of the drawing space. Despite being out of beta now. It's so dark anything you put outside the page (references or extra bits of modeling you make detailed views off of) are very hard to see.
Auto tables never fit my projects, so I keep the auto one off to the side and rewrite it with blended first and full levels to make easier for the shop guys to read.
I tried dark mode beta back in April and ran into 6 issues like this within 30 min of using dark mode. So I gave up on it until full release. And that was after it had already been in beta for over 3 months. Internal testing could be improved before features are released.
