Text alignment differs depending on theme choice
BWENGUK
BWENGUK
First off, thank you for introducing theme matching. Being able to use a dark theme is fantastic!
However, I've just come across an oddity. In the normal theme, if I change the surface speed, all the feeds update and stay aligned to the left, so you can read the whole number, but can't see the decimals. This is good. But when I have theme matching on, and it's in dark mode, doing the same means you can't see the feeds, as it aligns the other way. This is pretty annoying as you then have to click onto the feed box to see what it's changed to. I appreciate I could make the whole thing wider, but then that takes up more screen space....
See videos:
kacper.suchomski
Hi
It seems to me that all the parameter text boxes are narrower in the dark theme.
Can you make the dialog box wider to create more space for the parameter text boxes?
Kacper Suchomski
BWENGUK
@kacper.suchomski So in this case all I have done is switch between the two themes. I've not changed anything else, text size or otherwise.  You make a very good point though that I hadn't noticed, in that the text does look bigger. In the classic, it isn't overlapping the box at all.
So maybe the bug actually is that the theme change is changing text size, leading to this odity.
So my lead on question then, is there a way to make text that doesn't fit in the box show the left side, rather than the right side?
Note how the feed rates show the important bit, and cut off the decimals and units. But the speeds show the last couple of digits and the units. The former is much more useful.
kacper.suchomski
I don't think there's any way to change these settings. I'm convinced it's a hard-coded formula, not a user-friendly feature.
Kacper Suchomski
