Testing Screw hole alignment?
Hi Guys,
I'm trying to design a new motion system for my 3d printer.
I've got to parts I've designed that will be bolted together.
I'd joined the 2 parts joint via joint origins I'd add to each.
I've then inserted a screw from McMaster Carr and quickly used the align tool to insert the bolt into the 2 joined parts, then ran the interference toll to as a quick check to see If the holes are correctly aligned.
I get the following results
8.346E-07mm3
5.324mm3
I've not used this tool before, so I don't know if these results mean I'm going to have problems and the holes are out?
I've been rushing things as I've only got use of the software until January, so there are probably many mistakes.
