Template to send out for Vinyl cutting?
peteZ97TK
Observer Observer
peteZ97TK
Observer
Observer
How can I create a file (dxf) that is the correct size and dimension to send out to a printer for vinyl printing/plotting?
That vinyl will then be applied wrapped to that same object.
ClintBrown3D
Hi @peteZ97TK
Make sure that your view is set to a scale of 1:1 and the DXF will be 1:1.
If it's too big for the sheet, don't worry, the DXF export ignores this. In the image below, I have turned off my border and Title Block, the DXF output will only show the views.
I hope this helps
Clint Brown
Senior Product Manager - Autodesk Fusion
Book some time on my calendar
The Ultimate Guide to Drawing Automation
peteZ97TK
Observer
Observer
Thank you for the reply. I will give you suggestion a go!
davebYYPCU
You don’t need a 2d drawing
You can Save out the Sketch as Dxf, limited to one file per Sketch,
Or download DXFer from Github, - need a solid model and it exports the faces of all parts.into one file.
Then there is Manufacturing if you have the machine post suit your cutter.
Might help....
peteZ97TK
Observer
Observer
Thank you Clint. That worked!
