System inconsistency processing surface tangency error when combining
I am trying to fill the inside of a complex shape. To do this I used boundary fill with a couple planes to make a solid the shape of the area. However, when I try to combine it with the outside shape I get the error "System inconsistency processing surface tangency". Not sure what I can do to fix this. I tried changing the shape slightly by press/pulling and extruding, but no luck. I would appreciate any help with this.
jhackney1972
Please attach you model so others can test it to determine a good solution.
John Hackney, Retired
File is too big to upload so here is a dropbox link
https://www.dropbox.com/s/pg1j45ngxwdrl1d/problem%20file.f3d?dl=0
TrippyLighting
For future reference, here is an article describing how to properly share a Fusion 360 design 😉
lso, maybe you can explain in a screencast (recorded with the Autodesk Screencast tool) what you want to do. Your model is not self explanatory as to the purpose of the exercise.
jayBFJVX
Community Visitor
Community Visitor
can you share the fix here please for other users to see. thanks
TrippyLighting
@jayBFJVX if you are experiencing the same error in your model, please start a new thread and post your model.
This thread is quite old 😉
