sweep surface with circle as path
josef.schadlbauer
josef.schadlbauer
hi community,
lately i've been playing with the sweep command and i've been trying to get a hyperboloid as surface. so i've created circles and a line.
now i want to sweep the line along the outer circle to get a hyperboloid. the problem is, that the surface is not created for the full circle (an error occures). when i try the same for only parts of the circle it works. is there some possibility to create the whole surface?
thanks for your help.
josef
dsouzasujay
Hi @josef.schadlbauer
Can you check this video from BuMath Explorations can help create a hyperboloid in Fusion?
3D Design: Created a Hyperboloid as a Ruled Surface in Fusion 360
If my answer helped, please 'Accept Solution'
Join Fusion Insider
Sujay D'souza
Autodesk Fusion
TheCADWhisperer
@josef.schadlbauer
Are you OK with Pattern and Stitch?
g-andresen
it works this way too
günther
josef.schadlbauer
amazing, thx (:
josef.schadlbauer
i did this aswell, but it seems a little bit comlicated...
