Sweep self-intersecting
khojjesslyn
khojjesslyn
I'm trying to sweep this, but it kept on saying that its self-intersecting. The radius of the circle is 4mm, but I tried changing the radius to 1mm but it's still an error. I also tried reducing the number of curves and enlarging it. In the picture, that’s the maximum sweep, after that point it doesn’t sweep.
jhackney1972
You should attach your model for a better response.  Open the model in Fusion, select the File menu, then Export and save to your hard drive.  Attach to a reply post.
John Hackney, Retired
khojjesslyn
Here is the file. Sorry I can't save it in .f3z
jhackney1972
Your ZIP file only contains Inventor files.  Please attach the F3Z file directly.
khojjesslyn
Here it is.
jhackney1972
I broke the link of the Power Cord, in your assembly, so I could send the file back as an F3D file.  Do not use this file as it is just for illustration.  I created the Sweep from the opposite end of the cord as there was some issue with your sketch, which was not constrained by the way.  Model attach.
khojjesslyn
Thank you so much!!
