Sweep/Loft hybrid?
Sweep/Loft hybrid?
justphredrick
Message 1 of 11
Sweep/Loft hybrid?
justphredrick
Hi there, I am looking to create a complex surface.
I can Sweep a profile along a path,
and I can Loft from one profile to another.
But is there a way to go from one profile to another (like a Loft) along a path, perpendicularly (like a Sweep)?
Replies (10)
Message 2 of 11
lichtzeichenanlage
You can define rails to guide the lofted surface.
Message 3 of 11
justphredrick
I have tried that, and I get the Warner that "selected rail does not tough all of the profiles."
it's not acting like a Sweep.
Message 4 of 11
davebYYPCU
Change to Centreline Rail, and the message will be avoided.
Message is valid for normal Rails.
Might help.....
Message 5 of 11
justphredrick
I have tried that as well. got two different errors this time.
originally I was importing an SVG, bu then I tried doing evert thing in Fusion.
Message 6 of 11
justphredrick
this works when I used Sweep and set the orientation to Parallel. but there is no Parallel setting in loft, as there is in sweep.
Message 7 of 11
davebYYPCU
Works for me.
(Loft will not play well with careless constructions.)
Might help....
Message 8 of 11
lichtzeichenanlage
True, the loft is functioning this way. Here is a link to a good thread
that explains the different projection types to make rails work:
https://forums.autodesk.com/t5/fusion-360-design-validate/lofting-and-projection-include/m-p/7223604...
Message 9 of 11
justphredrick
What are careless constructions?
Message 10 of 11
davebYYPCU
You supplied 3 pictures where the intended rail is not connected to profiles.
Centre line Rail that extends past profiles, and does not penetrate profiles.
The Loft Tool has informed you that rails must involve all profiles, and you made no apparent changes, within the geometry.
Loft is finicky even with careful construction, but plain stops with your depicted geometry.
Might help....
Message 11 of 11
TrippyLighting
I have a feeling I know what he means, but to be sure it would help if you could share your design (export as .f3d and attach to next post).
