Sweep issues
Sweep issues
qkarmark
Message 1 of 9
Sweep issues
qkarmark
I am trying to sweep a blade for my part, and I am getting a warning about the path and the profile.
How do I solve this?
thanks
Quentin
Replies (8)
Message 2 of 9
MoshiurRashid
Hi
Thanks for posting. I can see you're using a guide rail. which is not exactly finishes along to the end point of the path. I think that is making a problem.
Moshiur Rashid
Autodesk Certified Instructor
ACP | CSWE
https://www.autodesk.com/expert-elite/overview
LINKEDIN | FACEBOOK
Message 3 of 9
qkarmark
thanks for your reply:
I have actually moved the sweep along numerous points of the guide rail ( to the full end, and partial distances etc) , I keep getting the same or similar errors.
Message 4 of 9
TheCADWhisperer
I have actually moved ...
Coincident.
File>Export and then Attach your *.f3d file here.
Are your sketches fully defined?
Message 5 of 9
qkarmark
I will have to save/attach the .f3d file when I return home... its saved on my computer, not the Autodesk cloud.
I want to respond 'no' to the question 'fully defined' however. ( I am obviously quite new to Fusion 360. )
Message 6 of 9
qkarmark
thanks again, here is the attached .f3d
Message 7 of 9
davebYYPCU
The warning for the sweep is  - for information - can be problematic, in your case not.
You have bigger fish to fry,
The sketch with the profile, has lost projections from somewhere.
Then the sweep is using the lost projections.
To make your blade you do not need guide rail, just the missing path sketch (Axis line of shaft) and twist angle,
You also have two move operations earlier, (that should be avoided), when the extrude can be edited to become the last position.
I have edited the file, place a dimension on my two sketches, for the accuracy you need.
Might help....
Message 8 of 9
TrippyLighting
Yep, true. But the object in question is part of a helix and the technique used to great the geometry is needlessly complicated. A sweep with a twist along the central axis of the cylinder is all it takes to create this.
Message 9 of 9
qkarmark
Thanks for your prompt response and solution: I have been distracted lately
so apologies for not showing my appreciation sooner - at any rate, the
solution you provided was adequate: I will take a closer look
