sweep failed after intalling new version 2.0.10813
infoYR5P9
infoYR5P9
After installing the latest available version (2.0.10183) I've got the following issue with sweep:
sweep-->choosing type, profile, path, etc. --> the sweep preview shows the intended surface --> clicking on "ok" it creates a completely wrong geometry. Please see the attached pictures.
Does anybody has a solution idea for this? I have to finish my task still today....!
Thanks in advance!
TrippyLighting
Please share your model. Export as .f3d and attach to next post.
infoYR5P9
Hi TrippyLighting,
an example file is attached.
Thank you!
jeff_strater
that is very bizarre.  That is clearly a bug, I will create that bug and send it to the modeling team.
[edit] created bug FUS-89647 for this issue
Jeff Strater
Engineering Director
TrippyLighting
Granted, that looks like a odd bug.
Looking at the design, however, I note the the sweep profile is not coincident with the sweep path.
It won't make a difference in the result of the sweep, it'll behave the same odd way, but I wonder what the intended end result is.
A simple surface extrude symmetric and 33mm wide would not result in the same geometry ?
