SVG import in infinite loop!
I am trying to import an SVG file  (the great avenger Maya calendar designed by (sandyeggocnc). He used a product from Aspire but I wanted to learn how to make it with Fusion 360. I have attached the SVG file to this post.
So, each time I try to insert the SVG file in Fusion 360, the import process is working in an infinite loop even after one day and one night spent to let it inserting correctly without success.
Is there a way to achieve this insert or could I prefer to try another software?
Thank for every people working on/with F360 and thank you in advance for those able to support me on this issue.
jodom4
Hey super_jb,
The problem here is your SVG. Some programs (including Adobe Illustrator) interpolate spline geometry into polylines when you export an SVG. If you have access to the original geometry (almost certainly made using splines), you might be able to find a program that will let you export it with splines.
Jonathan Odom
Community Manager + Content Creator
Oregon, USA
Become an Autodesk Fusion Insider
