Surface construction errors
niz828L2
niz828L2
This is how everything seems to work. BUT you need to insert one more section.
And it turns out such garbage. How can one explain the reasons for such a command when changing the number and parameters of sections of the body-surface? How to deal with and if the opportunity to correct such errors? How?
For comparison, there is an additional option “add a connector” and thus eliminate surface construction errors. Is it possible to add such an option? Those. expand the possibilities of manual adjustment of surface construction parameters.
I’ll note right away that using the “FORM” tool does not solve the problem, when building a “loft” the exact same situation arises, apparently the original mathematics is the same ...
g-andresen
1. Please explain the situation in a screencast.
2. Please share the file.
File > export > save as f3d on local drive  > attach it to the next post.
günther
