suggestion for fusion 360 team
830403205
830403205
It would be very nice if one could choose the design plane from the cube, this would be very handy and quick at times.
it would be a handy addition.
hope this helps
when can one post suggestions by the way
jhackney1972
If you would like to select the sketch plane using the View Cube, you can do that now.  Select the New Sketch command, then left click on the face of the View Cube you desire.  Once the view is oriented, left click on the origin plane facing you.  If this is not what you desire, please clarify what you do mean.
John Hackney, Retired
when u are sketching and say u want to choose a plane for a new sketch plane under construct .then it would be nice to be able to use the cube to choose the side for the new plane.
hopethis makes sense. otherwise u have to go to origin and choose say xz or other ,its a pain
max geyer
TheCADWhisperer
I don’t understand the problem description.
@830403205
Can you attach a *.f3d file that would help to illustrate the problem?
jeff_strater
@830403205 - while you cannot directly click on the view cube to create a sketch, you can get close.  If you click on the view cube, it will orient the view to that face, and in the New Sketch command, clicking in empty space will select the origin plane that is associated with that view.  You do not have to select the origin plane explicitly
Jeff Strater
Engineering Director
Hi
when choosing a plane u should be able to click on the cube in any function. in many instances u have to go to the origin to choose eg xz or yz. it would be nice to choose it from the cube much quicker and easier and spatial
Hi
when choosing a plane u should be able to click on the cube in any function. in many instances u have togo to the origin to choose eg xz or yz. it would be nice to choose it from the cube much quicker and easier and spatial
