Stupidly simple - how to move a sketch line without moving others!
alphatester77
alphatester77
Hi all,
Stupidly obvious answer I'm sure.
I'm trying to follow this tutorial to make a cone:
https://www.google.com/search?q=fusion+360+how+to+make+a+cone&oq=fusion+360+how+to+make+a+cone&aqs=c...
It suggests creating two circle sketches and then moving one in the z plane to allow a loft between the two, however when I'm moving one circle, the other circle moves with it?
I can't see any constraints etc, but they're obviously connected somehow!
Any pointers appreciated!
davebYYPCU
Will depend on Constraints.
Did you draw them on the origin?
Click hold on the centre points, if a coincident icon highlights, select and delete it.
Might help....
TheCADWhisperer
This is not the best way to make a cone as moving the circle off of the sketch plane would turn it into a 3D sketch.
Revolve of 2D profile would be a better technique than Loft.
g-andresen
my recommendation:  Never move sketch elements in the 3rd axis in such cases.
Do it like this:
günther
alphatester77
Ah, great solution Gunther! I'll use that from now on - thanks all for your help!
