I am getting the hang of Fusion 360, but am stumped on a few items in this model (http://a360.co/2y93jNK).
1) When I try to rotate the revolute joint (box hinge), I'd like the box to be stationary and have the lid rotate back and forth. Currently, the lid remains stationary and the box rotates. I'm not sure how to fix it.
2) I am concerned that the joint icons do not coincide with the actual joint locations. Am I doing something wrong that is causing this?
3) There is a component called 'Right Side Top:1' which has a rigid joint. As expected, when I double click the component in the tree view and then try to move the component, it will not move. But if I right click on the component and select Parent->Top, I find that I can move this component anywhere I want, thus violating the rigid joint. What am I missing?
4) Is there a way to get the wood grain to wrap around the box?, i.e. when actually making the box I would start with a long board and then cut the 4 panels from it. Thus, at the box corners, I should see the continuous grain pattern from the original single board.
Thanks!
Ron
