Student is stuck in sign in loop
alexander_hurst
Message 1 of 60
alexander_hurst
I have a student who appears to be stuck in some sort of sign in loop. When she opens the Fusion 360 desktop application on the school computer it asks her to sign in. She clicks on the button, the browser opens, and she signs in. A new tab appears that says "Signed out of desktop", "You're still signed into the browser so that you can access your account and forums". The only option on that page is to "Sign out of browser". The desktop application window remains as the "Sign In" window. She has an account, she shows up on my team, but she cannot access Fusion 360. Any insight is greatly appreciated.
Replies (59)
Message 2 of 60
RajkumarIlanchelian
@alexander_hurst This is likely because of the team hub not being fully approved. Can you please share the email ID of the student or if you do not want to share it here you can PM the email ID
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
Message 3 of 60
asyif_alamsyah
Observer
Observer
I have a same problem with mr. Alexander's student, where i stuck in sign in windows in desktop application. I'm a student myself who using education license and haven't yet joined any team. What should I do?
Message 4 of 60
RajkumarIlanchelian
@asyif_alamsyah When you created your account, were you asked to create a new team hub? If yes, did you receive an email to go verify the account?
Can you also please use your account and login to https://login.autodesk360.com/login and see if it asks you to join your hub?
Autodesk Fusion
Join Fusion Insider
Message 5 of 60
RajkumarIlanchelian
@asyif_alamsyah Can you also walk me through how you created your account? As in was there an invite you used to create your account. did your teacher/professor invite you into their hub that drove you to create an account? It shows that your hub was created on April 15. Do you remember if around that time was when you created your account?
Autodesk Fusion
Join Fusion Insider
Message 6 of 60
sfredericks-tcs
I have the same problem. We had planned on using the desktop version, but one student kept getting stuck in a loop. So, I abandoned the desktop and tried the online version. He still has the same issue.
I uninstalled fusion from the laptop. I tried different roles for him. Any ideas?
Message 7 of 60
ssmytheY689B
Observer
Observer
I am having the same problem. Is there a solution to this?
Message 8 of 60
evelynL5N4U
Community Visitor
Community Visitor
I'm having the same issue, not a student or teacher
Message 9 of 60
RajkumarIlanchelian
@evelynL5N4U If you go to https://login.autodesk360.com/login and try to login it should give you the option to send an invite again. Once you accept the email invite, you should be good to access.
Autodesk Fusion
Join Fusion Insider
Message 10 of 60
nicholas_hoang
I am having the same sign-in loop issue with a student and getting the webpage signed out of desktop message.
Message 11 of 60
RajkumarIlanchelian
@nicholas_hoang you can try a couple of things:
1. Re-invite  the student and let them know to accept the URL in an email they will get
2. You can also direct message me the email ID of the student and I can see what is happening in the backend
Autodesk Fusion
Join Fusion Insider
Message 12 of 60
nicholas_hoang
I have tried reinviting the student and still get the same issue.
Private messages keep telling me an HTML issue or that I have reached my message limit
Message 13 of 60
RajkumarIlanchelian
@nicholas_hoang Thanks for sharing the student ID. The back end shows that the student has a valid hub and an account.
1. Can the student log in to https://login.autodesk360.com/login
2. can they confirm is they can see your hub in there?
3. If the student tries to log into another machine does the same problem happen?
The backend seems to be how it needs to be. So trying out the front end options to see where the issue could be.
Autodesk Fusion
Join Fusion Insider
Message 14 of 60
AMADOfree
Community Visitor
Community Visitor
Hello, I'm facing the same issues, and I don't seem to get the invitation message even when I press resend!
My email is: abubaker@stanford.com
Message 15 of 60
RajkumarIlanchelian
@AMADOfree We are not able to find any record of this email ID in our backend.
Can you describe to me who invited you and if you already created your Fusion 360 account?
Autodesk Fusion
Join Fusion Insider
Message 16 of 60
m-10419957
Community Visitor
Community Visitor
Hello, I'm facing the same issues.
My email is: m-10419957@moe-dl.edu.my
Message 17 of 60
bd2023-sakshi_varerkar
Observer
Observer
I am facingthe same issue, where the Iget signed out of desktop and browser. It's a loop. the login link mentioned above, shows error when opened.
Message 18 of 60
RajkumarIlanchelian
@m-10419957 We are not ablate find this email in our backend at all? Can you confirm that this is the email and that an account was created?
Autodesk Fusion
Join Fusion Insider
Message 19 of 60
@bd2023-sakshi_varerkar Can you share your email ID in a direct message to me?
Autodesk Fusion
Join Fusion Insider
Message 20 of 60
Done
