Stuck on sign-in window, Fusion
TGSteep
Observer Observer
TGSteep
Observer
Observer
I reinstalled the Fusion several times, disabled anti-virus, reset it, repaired it, still stuck on sign-in window, I click sign-in and it says check your web browser but nothing happens, can't click again. Also I changed the default browser several times. It is frustrating, I was using it with no problem so far.
vinayak_dhame
Hi @TGSteep ,
Could you try steps given in the Support Article.
Let us know if this helps.
If my answer helped, please 'Accept Solution'
Vinayak Dhame
Autodesk Fusion
TGSteep
Observer
Observer
Okay, I found the problem, thank you. It's the problematic regedits, I deleted debugger blockeds and it worked.
RajkumarIlanchelian
@TGSteep I suspected that was the one.
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
