Stuck on offline mode since the last update (around friday).
marcin.szafranski
Message 1 of 23
marcin.szafranski
I'm having problems using Fusion at home since the last (I think it was on the last friday) update. It's stuck on offline/maintenance mode. When I connect my laptop via my mobile connection everything is working fine.
At home I'm using OpenWRT as router OS with Pi-Hole as DNS. And Gl-iNet Mudi 7 (on which the router OS is based on OpenWRT) as my mobile router.
Everything from this page is set: https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Fusion-360-cannot-...
Does it contain an up to date lists of domains? Maybe something was added with fridays update?
I've tried the Service Utility's Repair function - didn't change anything.
Any help will be appreciated.
Thank you in advance.
Best regards
Szafran
Replies (22)
Message 21 of 23
Siff3D
Hi @karina.harper,
Thank you for following up! I just re-enabled DNSSEC on my router and Fusion started and is on-line. I don't know what was the change that was made, but I'm hoping that Fusion will be stable now!
Message 22 of 23
marcin.szafranski
Just checked - in my case Fusion is now working with DNSSEC enabled on PiHole.
Best regards
Szafran
Message 23 of 23
dylan.levin3
Observer
Observer
I can also confirm Fusion is now working with DNSSEC enabled on my network. Thank you for resolving this.
