Stuck in upload processes no matter what I try
hatch789
hatch789
Hi Guys, This is a really terrible story and I've tried literally every thread I can find on the subject. Nothing helps. I have de-installed / reinstalled F360 about 10 times trying to get this issue resolved. I have gone through all of the new (Feb 2023) document steps 2x on a total clean de-install / reinstall of F360 including removing all registry items. Finally today I reloaded my PC (laptop) from scratch. This PC is my work PC (laptop) and I use the same Autodesk account from home. My home PC works flawlessly and I can get in and save files no problem. Even files that are locked here on my work PC and stuck I can go home, grab an earlier version and SAVE AS LATEST. But whatever I try to save on my work PC (even after this latest reload of Win10) it takes a LOT longer to save even a simple file. Anything complex with CAM in it, seems to just hang and hang. It's crazy and I'm pulling my hair out. HELP! I'm going to take my work laptop home tonight to continue testing from home but I need help guys.
RajkumarIlanchelian
@hatch789 I had our engineering team look at the log files (thank you for attaching them) and it does show that uploads failed due to a time out. This generally happens if it is a slow network.
When you are using your work PC at home when this happens, are there anything that could slow your machine down? If you run a speedtest does it show a slow network?
Does reseting the router at home help move things forward?
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
