stuck in an infinite loop when i sing in in the app fusion 360
Totochnat
Totochnat
i have the same problem as this one :
Stuck in Sign in loop or hangs when accessing Fusion 360 (autodesk.com)
but instead of a white screen I got this screen:
Can you fix it ?
thank
RajkumarIlanchelian
@Totochnat @This is likely because you have not accepted the hub invite in an email that you should have received.
please login to login.autodesk360.com and it should have a link to send you the email again.
if for any reason this is not working please direct message me your email ID.
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
Community Visitor
Community Visitor
19014795-017@uog.edu.pk
RajkumarIlanchelian
@19014795-1 What problem you are having. Using your email I see that you have created a new project today in Fusion. Is there any help that you need?
Autodesk Fusion
Join Fusion Insider
