Strange problem after installing Autodesk Fusion.
w_kapel
Message 1 of 1
w_kapel
Hello, i don't know if i am on the right forum, i hope so.
This is my problem. I have shortly install Autodesk Fusion, before i had Fusion 360 en had no problems with this version til a few weeks ago. Fusion 360 wont start anymore so i install Fusion free version. The first problem that i get was that when i do a post processing to make a gcode i get different errors. So i search on the internet and found that the problem was that i had a old GRBL.cps version and must install the newest OpenbuildsFusion360PostGrbl.cps. That was to resolve the errors. But then i got a bigger problem. When i saved successfully the gcode to the computer and load it into Openbuild Control it load the file. But it wont run, if i push on the run button nothing happend. Simulating works fine. So i tested with Universal g-code platform/sender[ugs] and gSender its works flawless no problems at all..
Gcode that i made with Fusion360 works without problems, gcode made with Fusion none get loaded.
Is somebody else with the same problem or it is maybe a bug in Fusion or in the Openbuilds360PostGrbl.cps?
I hope somebody will help me because i cant find the solution.
My English is not my main language, sorry about that.
Best regards, Willem
Replies (0)
