STL Issue
STL Issue
pastor.healer
STL Issue
pastor.healer
I have a component with a hole in it for a M6 screw
I tried to add an M6 screw to the hole with the threads whereas I could print both at the same time.
In the 3d Print dialog, it tells me to select the component or body and all of it highlights, even the
M6 screw.  But the M6 screw doesn't show up in the STL file.
Do I need to make this an assembly first and then send it out ?
Thanks for the support
saito.kh
Autodesk Support
Autodesk Support
Hi @pastor.healer,
Thank you for posting in the community!
Can you please try some solutions in the below article and let me know if this helps?
https://knowledge.autodesk.com/support/fusion-360/learn-explore/caas/sfdcarticles/sfdcarticles/How-t...
If this does not help, would you mind sharing a public link to the model file so that I can take a closer look at this on my end?
Thanks.
Kanehiko SAITO
Product Support Specialist
Fusion Webinars | Tips and Best Practices | Troubleshooting
