.STL export no longer works
mick26730
Observer Observer
mick26730
Observer
Observer
Hello, I use fusion 360 for personal purposes to draw and then print the parts with my 3D printer. I select the part to convert, I choose: export, then the .STL format and I save it in the folder I chose.
It always worked like this, but now the "task status window opens", the name of my task appears,
but remains unfinished indefinitely.
I don't know what to do, I reset the fusion360 settings, but it doesn't work any better.
I also reset the network settings on my PC under Windows 11 and nothing better either.
Thank you .
mick26730
Observer
Observer
I did some tests, my old 3d drawings can still be converted to STL, but the new ones no longer work.
TrippyLighting
You can select the object (body, or component) in the browser in Fusion 360's viewport, right-click and select save as mesh.
That will  provide you also with more options to control the mesh resolution.
