STL export is about 5% too small
Message 1 of 27
I have exported designs to cura before and they printed fine.
But recently, prints have been about 5% smaller than the design.
Replies (26)
Message 2 of 27
taylorhsbennett
Sometimes the easiest thing to do is the math based on a ratio , for example take the same two distances between two points one from the stl file (the small one) and then the fusion the right one you should come up with a ratio of difference . Punch that ratio back into the stl in some other program to scale and enlarge it and then perhaps this will solve your problem.
Message 3 of 27
Uum, no. That's pretty unacceptable.
A design should transfer and print at the proper size.
Especially sine it had been working fine until recently.
Message 4 of 27
taylorhsbennett
Yea well I am having issues since last update also. Just saying that you could scale it if you had to as a temp fix , I know major headache but better than nothing.
Message 5 of 27
I have been scaling. but it's indeed a PITA.
Message 6 of 27
dsouzasujay
Hi @Anonymous ,
How are you exporting the .stl file to Cura?
  • Are you using file>export> Export with .Stl format? or
  • Right click on the top fusion 360 browser node and 'Save As STL'?
If my answer helped, please 'Accept Solution'
Join Fusion Insider
Sujay D'souza
Autodesk Fusion
Message 7 of 27
jj.space
Same Here!!   Hope there will come a solution to this...
Message 8 of 27
dsouzasujay
Hi @jj.space @Anonymous
Can you attach the design that you have created in Fusion 360? You can export by File>Export *.f3d/*.f3d file to your local drive and then Attach it here to a Reply.
How are you sure that the exported mesh file is 5% smaller, how did you confirm?
Join Fusion Insider
Sujay D'souza
Autodesk Fusion
Message 9 of 27
jj.space
hi,
It was my very first design for my very first 3d printer
I have no longer the files, I have deleted them. Maybe you can recover them from my autodesk recovery bin (if that exists??)
I made a simple tube with 2 x sketch center diameter circle command, inner circle 5.0mm, and then extruded to a tube.
Stl of that object.
into Cura with had no problems fit-printing other pre-designed objects.
and this tube did not fit the 5mm steel axis what is was intended for.
I measured it with a caliper - i am used of this
it turned out to be 4.5 mm inner diameter…
so in cura i rescaled the model to 111.11 %
et voilà: I ended up with perfect 5mm inner diameter tube that fitted snuggly on the 5 mm axis…
Message 10 of 27
dsouzasujay
Hi @jj.space ,
You can recover your deleted files from A360.
Go to your project and you should be able to see Trash.
If you can share me the *.f3d file i can help you out.
Join Fusion Insider
Sujay D'souza
Autodesk Fusion
Message 11 of 27
jj.space
I re-did it and same result :
inner diameter should be 5.0 mm, it printed as 4.6 mm
outer diameter should be 8.0 mm, it printed as 7.9 mm
Message 12 of 27
HughesTooling
Your STL measure correct.
This is quite likely down to the small size of the part and printer moving too fast and dragging the extruded material. Or heat build up in the part and shrinking. With FDM printers holes quite often end up under size, try printing something 50mm square and measure.
Mark
Mark Hughes
Owner, Hughes Tooling
Message 13 of 27
TheCADWhisperer
What is the tolerance of your printer?
Is it a $1000 printer or is it a $50,000 printer?
What material does the printer use?
Message 14 of 27
jj.space
The strange thing is that I printed a ready made tube stl found on thingverse for that 5mm axis, and it printed perfectly snug, same printer, same filament...
Message 15 of 27
TheCADWhisperer
Attach file here.
Message 16 of 27
jj.space
That little part: it has o hole in it that printed exactly snug fit on the 5mm steel axis.
Message 17 of 27
HughesTooling
Are you sure the second STL you uploaded here is the one from thingverse  because it's exactly the same as the first file you uploaded! Exactly the same mesh, which is surprising if it was made with different software.
This is the origin one in blue and the second one would show black if there were any differences.
Not a single mesh triangle is different.
Mark Hughes
Message 18 of 27
jj.space
The tube-stl with "problems" is 3mm high, the tube-stl without problems here is about 10 mm high and has also a gyro-spinner in the stl...  That is the only thing that I can say on this. (I am very novice!)
Message 19 of 27
HughesTooling
Sorry might have saved to the wrong file when I downloaded the second one. With the last set of files there where several rings in one, I guess the one dimensioned below is the one you used and it has a 5.5mm hole.
Mark Hughes
Message 20 of 27
jj.space
Thanks for checking this all out! Niw I know that for small diameter I have to be careful in my design for this my first Monoprice select mini v2 $200 printer 👍🏻😁👍🏻
