STEP-Exporting issue
InDezign
InDezign
Hi everyone,
I encounter an issue when exporting a certain file to STEP format.
Attached is the visual (company brand blurred).
While (A) shows what's supposed to be the final result, (B) shows what is being exported by Fusion 360.
Is this a known issue?
Has anyone encountered the same issue?
KR
Eric
dsouzasujay
Hi @InDezign,
Sorry to see that you're facing this problem.
Would you be able to send the file to (Sujay<dot>dsouza<at>autodesk<dot>com)?
That'll help us investigate the issue and see if there can be any workaround possible in the meantime.
You can File>Export your *.f3d/*.f3z file to your local drive and then attach it here to a email.
If you find my answer solved your question, please click the "Accept Solution" button
Sujay D'souza
SQA Manager
Quality Assurance
Autodesk, Inc.
InDezign
On its way.
Thanks!
PeterA4L
So what's the solution?
dsouzasujay
Hi @PeterA4L,
Are you facing similar problem? If yes, then can you please share the dataset having problem?
The solution was communicated through email, Apologise for not updating here.
Solution: The last extrude feature was creating extra semi-sphere(which was a bug), I have to extrude it as a new body(instead of joining the bodies while extruding) and then combine all the bodies again.
Reported this issue internally with ticket FUS-97848
Sujay D'souza
SQA Manager
Quality Assurance
Autodesk, Inc.
