Static Stress Simulation fails
2511965m
2511965m
I have been trying to conduct static stress simulation but it always fails.
It used to get stuck at around 50-80% while meshing, but that could get solved by making the model less complicated. However, it now fails at the solving stage. I have tried so many times and I have modified the model slightly sometimes but it never worked.
I have attached a few screenshots of the fusion360 screen and I can provide the fusion file if needed.
Is there any solution to this problem?
thank you
henderh
Hi @2511965m, the Solver Data -> Solver Output command may have the solver log that explains exactly why the solved failed.
I'm curious why it failed, and we can look into it more closely if you can provide a link to the F3d with the study setup.
* File -> Share -> Public Link
We apologize for the inconvenience this is causing, and appreciate you bringing this to our attention.
Best regards,
Hugh Henderson
QA Engineer (Fusion Simulation)
2511965m
thank you for the response. However it could get solved now, and it seems like it always failed when I tried to solve it locally, but it did work when I solved it on cloud.
It used to get stuck in the middle of meshing when I was solving the simulation on cloud, so I hadn't used cloud since then but after simplifying my model, it worked.
it still fails when I solve locally but as long as it works on cloud, I think it is alright.
kind regards,
