Static Stress Analysis of Connecting Rod Assembly Tutorial Difference in Results
dvdsnyd
dvdsnyd
My name is Dave Snyder, this is my first post here. I have a couple questions regarding static stress simulations.
I am going through the static stress simulation tutorials, specifically the connecting rod assembly example.
When it came to trying to solve the problem, I couldn't solve it locally. I received an error. in my solution. I couldn't get my results. I read somewhere that people had success with reinstalling Fusion. I did this, and this time around, the solver sat at 1% for about 15 minutes. I finally cancelled, and solved it in the cloud.
My computer is a bit dated, but was a mid-high range computer about 5 years ago Other than this issue tonight, I haven't had any issues running Fusion. Any thoughts on what could be going on with local solutions?
The second part of my questions come from differences in the solution compared to the given answer in the tutorial. I also receive a warning about the safety factor being under 3. The differences can be seen in the attachments. Most notably:
My Results for Von Mises stresses:
Max - 20772 psi
Min - 67.8 psi
Expected Results:
Max - 21653 psi
Min - 46.82 psi
There isn't a huge difference, but it's large enough for me to question and want to try to understand before I start to apply this to my own applications.
I really appreciate any and all help with this. Please let me know if I can provide any more detail!
Dave
ahreum.ryu
Autodesk Support
Autodesk Support
Hi @dvdsnyd
Welcome to the Fusion 360 community!! Heart
Regarding the Local solving issue, Have you seen this article?  Unable to successfully run local solve analysis within Fusion 360
Regarding the different result, I have recorded following instructions, and I got the similar result as expected. Would you mind taking a look at that? could you let me know if you find something else?
http://autode.sk/2wXB3Kc
And please find attached the model file. Hopefully this will help Smiley Embarassed
Many thanks,
Ahreum.
dvdsnyd
HI @ahreum.ryu
I was able to locally solve your provided file on my machine. It just took a little longer than I was anticipating. I did get the same results as you showed. However, the results are off from the example.
Again, the example solves to:
Max stress - 21653 Psi
Min stress - 46.82 Psi
The results from your analysis are:
Max - 21750
Min - 43.51
The minimum stress is not in the correct location compared to the example.
I went through the tutorial once more. I noticed that in step 10/29 of the guide. The guide says to click on two edges. The model that I downloaded had 3 edges. I noticed this in your model as well. Not sure if this would affect things?
I was able to once again locally solve and I obtained the same results as the results I reported on in my first post.
The results are close, but again, I am troubled that they differ from the tutorial. Any help in understanding why would be greatly appreciated!
Dave
dvdsnyd
Hi @ahreum.ryu
Have you had a chance to look at my response?
Thanks for all your help!
Dave
TheCADWhisperer
What are your mesh settings?
Have you run a convergence analysis?
Export and attach your *.f3d file here.
dvdsnyd
Hi @TheCADWhisperer
Thank you for taking a look into my problem!
I have attached the .f3d file where I ran through an adaptive mesh study. (as well as a file where I did not)
The convergence plot definitely tells the story of some singularity issues within the model as shown below.
This all came about by just trying to go through the Autodesk tutorial found on the learning site. for simulation.
The tutorial doesn't mention any sort of adaptive mesh or convergence.
I would expect that I should be able to get the same result as the tutorial.
I really appreciate any and all help!
Dave
ahreum.ryu
Autodesk Support
Autodesk Support
Hi @dvdsnyd,
Sorry for the late response.
Fusion 360 option has changed a lot since release. As of now, we don’t know which convergence values the tutorial uses. We would have a different result following the convergence option.
I would like to explain about the convergence. For example, if you set the convergence as 5%.
1st results = 22000 (range of 5% = 1100)
= the 2nd result should be within 20900 or 23100 (but 2nd result is over 23100)
2nd result = 24626 (range of 5% = 1231.3)
= 3rd result should be within 24626+1231.3= 25857.3 (+/- possible)
3rd result = 25525
= 3rd result is within 5% average, so it stopped.
In FEA, a finer mesh typically results in a more accurate solution. However, as a mesh is made finer, the computation time increases so we should find appropriate mesh.
I have changed the convergence options, and this is the result below.
Along with the Refinement option, the result and mesh have different values and runtime. Therfore I would like to say we should find the satisfied values between running time and results.
For your reference,
This is help of Adaptive Mesh Refinement: http://help.autodesk.com/view/fusion360/ENU/?guid=GUID-9AA69E6D-F278-4E40-AEFD-AEE1BDA97957
Understanding Singularities: https://www.autodesk.com/products/fusion-360/blog/quick-tip-singularities-and-simulation/
If you have further questions, please let me know Smiley Happy
Many thanks,
Ahreum.
