Standard Hole Template
96flintj
Message 1 of 1
96flintj
I have a countersink hole configuration that I use often.  When I go to add the hole I have to edit all my parameters (Angle, diameter, etc) to have the correct configuration.  Is there a way to save the configuration so I can click on the point that I want a hole and my configuration will be retained or is there a way to select my hole configuration from a drop-down or something?  I have to think there would be a way.  Thanks!
Replies (0)
